12.04.2008, 12:33 PM
Nice to see the truck running well at last, its been a long old build. On the cvd issue, you can buy a device called a 'bone saver' (anyone remember that conversation, one for the history books..) that you can use to extrace and replace the broken pin with, if the press doesnt work.
jordan...
one.five.two.seven
12.04.2008, 08:18 PM
nope got the standard erevo/revo diffs in it. yes i have run it a few times i justput 50000 in the CD 30000 in the front and 7000 in the rear to get it to handle better. it will still wheelie to my hearts content but not as easy as before. i will have to get the truggy diffs in it soon to take care of the speedy but so far it is doing fine. the only time i got it to trip the fuse was when i was putting it through its passes on 4s. i had it in an area about 3x3m and was making it wheelie non stop from one side to the other for about 5 mins straight. as soon as i hit neutral on the tx it reset and was fine. it would run better with better batteries. at the moment i am running maxamps until my flight powers arrive. i think i will put in the truggy diffs and play with the gearing to get some middle ground
good idea, what voltage are you going to be running with the Flightpowers, still 4s? I think i'm going to try 50000 in my CD, and maybe 75000 if that doesn't lock it up enough.
Thanks Neil. Ahh yes the bone saver, i was searching through the arcives and i think i saw something from '06 on that? Definately has been a long build, pretty much exactly 12 months, time flies when you're having fun i guess
Hey Jordan..
It was great to see it starting to finally take on speed!.. I'm sorry to hear / see your current issues. On the positive side, now you can prepare for this repair in the future as well to cut down on (down time). Example My truck has a few weeks points and I've learned them so when it brakes I've got spares, now you know a week point of yours too so it’s kind of good thing (sorry just trying to positive spin a shitty situation!) LOL.LOL..
Best of luck Jordan..
P.S.
It’s an awesome build…
Thanks Shaun. The speed is getting there, still would like it a bit quicker, but im working up to that. I'd rather that than just stupidly fast straight away, and two stripped diffs and broken driveshafts. At the moment i dont think that that was a weak point on the truck, more operator error I musn't have tightened them up enough, thats whay they came loose. All the other corners held up ok though, so thats a plus. Hopefully with some thicker diff oil it'll gain some punch off of the line.
