TDC57
TDC57's Avatar
12.06.2008, 12:17 AM
Ok so it's friday night got any pictures yet???
Nothing!.. Hahahahaaa..
12.06.2008, 12:48 AM
Sorry, going to Disney World tomorrow for a week, so I had to work alot. I did get a test run and decided that I need a better rec cover than a balloon. So I decided to use an erevo rec box, which has proven to be waterprroof.
I also killed the titan 550 12t, so I will try the titan 23t with a larger pinion. I also removed all of the plasti dip on the esc to see if it sealed ok. No water, so I sealed it again. Steering servo still works fine, but I need some waterproof grease for the kingpins, as they are getting very gritty.
I also narrowed some tamiya vice crawler tires (from the land crusier kit) and cut them down to fit on the 1.9 wheels. They were 2,2 to start with. The stock high lift tires just get coated in mud too fast. These tires are about .5" taller overall, and do not look as scale, but should perform better. Going to add some weights in the front too.
I will have some pics when I get back and reassemble the truck. The pics will be better as I can do a "build thread) of sorts.
