12.08.2008, 09:10 AM
I have the FLM rear arms and they come with hinge pins I think - They are black so maybe a slightly different size than the traxxas ones. I would run through a 3mm drill and I also put a little lithium grease on pins.
RPM arms - No comment on the arms as seems very odd - however if it is a field issue why not prep up a spare set of arms for the pit box.
Ahh the joys of putting everything together and taking it all apart again - I had the same issue but wasn't sure if I hadn't missed a shim...
