12.10.2008, 08:19 PM
4s will run, it has a built in BEC. What is the point of spending all that money on a Jive and not going high voltage? I think a jive 80 HV and a neu 1515 2.5y or a mega 22/45/3E would be great for 12s...
othello
HV basher
12.11.2008, 05:59 AM
>the new jiveīs have backwards too... i have read it on the manual!!
The manual states that the car mode is only "one direction" with proportional brake. There is a special mode which has the same effect as if you would switch 2 of the 3 motor cables ... reversing motor direction.
It's a matter of sofware. The jive ESCs do miss the second car mode (which you will find in Jazz ESCs) which had reverse incorporated.
