dirt101
dirt101's Avatar
12.10.2008, 09:04 PM
and anyways you should know at 892 post that when you run a pack in paralel you dont double your c rating just your mah.
rustler, lx2e, xxt cr
ICUBoy
12.10.2008, 09:33 PM
I thought you DID double the C rating- surely each pack now can source the original C rating, and now there are two? MAh will be doubled, and voltage will stay the same? Maybe I need more sleep but the total power the packs can deliver will double (whereas in series the voltage doubles but the mAh and C rating is the same given the same load and no voltage sag).
