Nomadio Sensor on MMM Esc
rustyj
12.12.2008, 10:06 AM
That's what I'm running.
Had a setup problem at first, used the castle link s/w to increase the time for it to arm, been working great since.
As an additional note, the first receiver I tried to use wouldn't work properly, tried it with a backup and had no problems.
rustyj
Find all posts by rustyj
Sensor
2
transtalon
Sensor -
12.12.2008, 12:31 PM
Thanks for the tip, Rusty. I was pretty bummed out when I couldn't but I'll try that to see if it works.
transtalon
Find all posts by transtalon
Sensor
3
transtalon
Sensor -
12.12.2008, 12:44 PM
Can you tell me your setup points if you don't mind. I changed the arm time to 5 seconds but it's still not working. I did have the Sensor to Reverse OFF.
Thanks in advance.
transtalon
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
Off
