speedracer1129
12.13.2008, 06:07 PM
That will be all relative to your gear ratio. The more speed you want, the higher the amp draw will become. I would suggest to get the biggest thing you can, at least 100amps continuous. Actually, you might be well off with one of lutach's ESCs.
Marvin
THE Paranoid Android
Marvin's Avatar
12.13.2008, 06:19 PM
I'm looking for at most 40mph, 5s 5400mAh, using a 1900kV motor, and I have no idea what the current will probably be.It's going in an 808 with 'standard' (16/42) gearing. Apparently using RC-Calculations it will reach ~35000 rpm to get 41mph (no drag), 39mph (with drag).
