wayneb
12.14.2008, 05:12 PM
I'm thinking about converting my savage to a brushless system since I have a feigao brushless motor just collecting dus on teh floor or desk or wherever it gets moved to next. and since I can't get the engine in it to run anyway, I just thought of doing a 1/8 scale brushless. but I have a question. can I gear the motor to have less torque so that I can keep my three speed tranny in the truck for a little while? until the savage flux comes out. and then i can use the tranny from it in my savage. or lock my other two speed tranny?
Janezki
Avid Gear Crusher
Janezki's Avatar
12.15.2008, 05:01 AM
Gearing doesn't much effect the torque, use lower voltage if plan to have mercy on your tranny.
I presume that's an XL Feigao you have there, what is it's kv rate?
If you have a second tranny, then why not locking it - then you have reverse plus motor brake, depends from your ESC ofcourse.
12.16.2008, 11:13 AM
Actually, gearing does have quite an effect on torque. If the motor has say 0.3 fl-lbs of torque at the shaft for a given amperage, gearing down 20:1 increases the gearing factor, so it's 6ft-lbs of torque. Reducing the gearing (increasing the ratio) increases torque at the wheels.
Janezki
Avid Gear Crusher
Janezki's Avatar
12.16.2008, 12:38 PM
Oops.. I was thinking of torque that is effecting the transmission, but thanks for correcting me.
