rootar
rootar's Avatar
12.15.2008, 01:51 AM
i always use to chuck the shaft up in my dremel and turn it on 5,000 rpm and run it in water for 2-3 min and then spray them out with brake cleaner or motor spary, put a couple comm drops and couple drops on bushing lube and they were gold,
my dad use to keep some dry ice in a brown sack in an insulated bag, and used a ladle spoon to get a little and set it on the motor's can
rchippie
rchippie's Avatar
12.15.2008, 02:04 AM
A lot of the oval guys use a motor cooler . It acctually gets the motor so cold there is frost on it . .
http://www.rctech.net/forum/r-c-item...er-i-make.html
REAL MEN RUN BRUSHLESS
