12.16.2008, 11:13 AM
Originally Posted by Janezki View Post
Gearing doesn't much effect the torque, use lower voltage if plan to have mercy on your tranny.
Actually, gearing does have quite an effect on torque. If the motor has say 0.3 fl-lbs of torque at the shaft for a given amperage, gearing down 20:1 increases the gearing factor, so it's 6ft-lbs of torque. Reducing the gearing (increasing the ratio) increases torque at the wheels.
Janezki
Avid Gear Crusher
Janezki's Avatar
12.16.2008, 12:38 PM
Oops.. I was thinking of torque that is effecting the transmission, but thanks for correcting me.
