MetalMan
MetalMan's Avatar
12.18.2008, 01:53 PM
- Come up with a decent way to seal the diff so I can tune it. There was an article in an R/C mag I saw at the LHS that describes how to do it. Basically, you dremel down the outdrive raised part flush with the rest of the diff. Then, countersink the outdrive hole and put an 8th scale o-ring in there. The o-ring should stick out as far as the original raised section that was dremeled off. Then add a thin shim, then outdrive bearing. To seal the diff cover, some RTV silicone. I have an extra diff that I'll be trying this on. But I'll wait to actually replace it until the existing diff goes out.
A friend/coworker is coming over to my "shop" today, and we are going to modify his Slash diff in this exact fashion. If there's time we might get around to modding the diff in my Rustler but that's not so important.
Do you have a drill press Brian? I think that will make drilling the countersunk hole a lot more precise.
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
12.18.2008, 03:59 PM
[QUOTE=MetalMan;243150]A friend/coworker is coming over to my "shop" today, and we are going to modify his Slash diff in this exact fashion. If there's time we might get around to modding the diff in my Rustler but that's not so important.[QUOTE]
Mind Taking a few snapshots? Mine Unloads badly after about 5-10 packs through it. you can even see the grease on the output yoke bearing. Horrible... Thank you Sir.
