Gee
A Horse's Ass
Gee's Avatar
12.21.2008, 08:30 PM
Hey this is going to be pretty cool. Push a button on the controller and it starts. Electronics, small lipo, soldering iron, wires, an esc installed. It's like a hybred.
We (you) have got to come to peace with our inner issues at some point or they will burn us (you) up from the inside out. You have got to now the Nitro guys are hurting. They are starting to see the light. Someone should at least be able to communicate with them when their ship landsl.
SeanZ0r
12.22.2008, 04:52 AM
Yo gee, Thats a cherry roller you picked up. This is going to be a pretty cool setup, I saw that exact write up in RCCA. I would run a 2s Lipo like 2000mah or w/e can fit to provide power for the start up system, and also solder a CC bec or similar to that to provide power to the eletronics so it's just one big battery that you have to charge. The CC Bec from castle will flash a red light, and more importantly shut off when the input voltage gets to the level that you set the output voltage to..So If you set it at 6.0v(what voltage a fresh receiver pack puts out) this will be a form of a cut off for your 2 cell lipo.
Did you see my brushless jato? It's worth it, but you already have a motor to be put in order, that will be balls out quick as well.
AE Factory Team TC4 4c2p 6000 & MM 5700
Brushless Traxxas Jato MM 5700
SH Z-Car MMM2200/5s4000mah Turnigy Packs
