brushlessboy16
brushlessboy16's Avatar
12.23.2008, 10:42 PM
Well, I just got a zippy pack from another member, and one of the copper tabs had broken the al piece off the cell... Bad idea, they should either stick with longer once piece al tabs or have a one piece copper tab. I will attempt to solder this back on. I am guessinf the slight flex of the pack cause the heavier copper tab to tear the al portion off. The crimp weld between the two was still intact. Guess you do get what you pay for...
On another note does anyone want a 5000 4s zippy... I will let it go cheapish...
ME! :)
PM me.
and i soldered mine back together. only one run on it so far
12.23.2008, 10:56 PM
ME! :)
PM me.
Hopefully your solder holds...
I sent you a pm...
