12.24.2008, 10:23 PM
Not sure if they will work. Most 2.2 bead locks center mounting hole is larger than what is normally on your truck. I bought a set for my crt.5 and had to return them for this reason. The only way to be sure is to measure the hole diameter and match it up to your truck.
BL Dreamer
12.24.2008, 10:52 PM
Can you just drill the hole to size, I figuer the hex is the important part. I may be wrong in this assumption.
