Joram
Nitro?? BL rulezzz
12.26.2008, 11:56 AM
danhfvcsd,
Any updates?
Greetz,
Joram
Standard is not an option!
  Send a message via MSN to Joram
Savage03
12.26.2008, 02:39 PM
Not as much bling but could go back to X stock towers and Innovatives mounts, what im using. After getting everything installed I noticed the lst shocks gave some serious down travel little more then I liked after seeing the dogbones almost rubbing and possible could pop out so maybe put some spacers in the shocks to limit them a bit, I used the rubber stops on the stock shocks. Also I see your on the 6th hole on those arms and I see a 7th can you mount to there maybe? Just some ideas but I have no clue with the aluminum stuff, never would invest in metal arms and towers I have seen many bent and for a hard bashers the stock ones are more then adequite and dont break.
