12.27.2008, 01:13 PM
Originally Posted by Gee View Post
Thanks. Next time I read a thread of yours about your scale crawler(s) I'll have a better picture of what you doing. Sound like a fun project. Are there a lot of parts for builds like your doing or does it take a lot of fabricating your own suspension, chassis, etc?
There are quite a few parts available. I have made 2.2 comp style chassis and links from scratch before, this time I got a good deal on the chassis and axles and he threw in some of the links (jato turnbuckles) and I happened to have a few spare jato turnbuckles laying around. I am going off of reign rc website that has a build using the same chassis and axles. The reign chassis are setup to use the same length upper and lower links, so it makes it real easy to get the geometry close. That is the worst part for me, making sure the suspension is smooth and the axles are controlled well during crawling. This 1.9 has a short wheelbase (less than 10") to match the blackfoot body, most aim for an 11" WB and the revo pushrods are the most popular links used, they are steel and have solid rod ends!
Originally Posted by saydee1800 View Post
NIce truck very real looking. Hey to bad you can run that lipo you got in the picture. (that would be one fast truck!)
Nice truck
Thanks! Yeah, that lipo is out of the lst, it and my cell phone make the perfect height center stand. I had to do that to figure out the shock lengths. 6s lipo in a crawler would be fast, that is for sure!
Originally Posted by TexasSP View Post
Looking good linc! I like those reign chassis, they look nice and solid. Don't see room for any chassis flex there.
Thanks buddy! They are super solid. I have this chassis and just got the k2-6 chassis for my 6x6 tlt axle truck that I will build next.
Progress!!!
Progress!!! - 12.28.2008, 02:42 PM
Ok, got it rolling. Using 4 tec shocks on the front, and rustler fronts on the rear. It is setup fully sprung in the front, and about 3/4 sprung in the rear. So the rear axle can drop out a bit, and the springs keep the tires off the body on the rear when the truck is fully articulated. Still need to trim the front of the chassis down. I will wait to do that untill I have all of my axle parts in. Also need to mount the pede tranny, but I want to set te axles up finally before I do that.
