JThiessen
JThiessen's Avatar
12.28.2008, 01:40 PM
I gotta weigh in on the side of caution here. You will be shipping something that is potentially explosive. There are proper means of doing this - contact your shipping company of choice, and they can tell you what it would take to safely ship this item. It may end up being prohibitively expensive. Maybe getting an ammo box at a surplus store, and ship it in a lipo sack would be sufficient. The weight of the box will drive up your cost, but it'd be safe.
Now, on the other hand, if one of those jumbo's does go down, it'll likely mean another order for us, and I'd love to build another airplane! Just kidding......the fire suppresion systems would quickly have that fire put out, and all we'd have is a few soaked and charred packages - and more than one unhappy customer.
12.28.2008, 03:42 PM
I guess the salt bath is the best way to completely discharge a lipo. A std nimh light bulb discharger is definately not safe.
As far as shipping goes, a properly padded package should be fine. Tape the holes with something non conductive and the same with the tabs. Unless the lipo shorts it will be fine. Remember that we ship non dmamged lipos all of the time, and the same sharp object could stick thru the package and cause one of them to catch fire. Caution is fine, but blind paranoia does not do anyone any favors.
JThiessen
JThiessen's Avatar
12.28.2008, 06:13 PM
So is a damaged lipo considered as stable as an undamaged one? Not arguing, just wanting to know.
12.28.2008, 06:21 PM
Honestly if the cell is not puffed it has not undergone the chemical reaction that produces the gas that may makes the cell casing puff/pop. As far as lipo fires go, the internal anode and cathode must touch, or arc in some way to get the litium to ignite via extreme heat. I have had cells puff from overdischarge, and seen what happens when you over charge one (hooked a 12v car battery to a 1 cell lipo with jumper cables in the yard, it made a pop noise and smoked a bit).
As far as shipping goes, as long as the pack is not puffed, and does not have any method of shorting the tabs it should be just as safe as a new lipo. That means that if you stick a screwdriver (or something sharp) thru either it will produce the same result (some smoke and heat). I have had torn case cells hanging around for months, all they do is smell a bit sweet (must be the paste inside) and take up space. I have read may different ways to dispose of lipos, and the vast majority just say to snip off the tabs and toss them in the garbage.
I have thrown them on the ground, stabbed then, run over them with a truck (f250) and never got anything until I hooked up the car battery. I have had worse smoke and heat from nimhs going bad....
JThiessen
JThiessen's Avatar
12.29.2008, 12:32 PM
Good info.
Why do I suspect some of the above were intentional?!?!
12.29.2008, 01:09 PM
Good info.
I have abosolutely no idea why you would think that...
