Takedown
WARNING: May become violent.
Takedown's Avatar
12.29.2008, 01:46 PM
But what if the part your spraying have alot of ridges? That would take awhile with sandpaper grit.
RIP- Tammy (9/14/08)
mikey09120
RC-Monster Stainless Steel
mikey09120's Avatar
12.29.2008, 03:35 PM
thats why my dad has a sandblaster. most engine repair shops have one. ask to borrow it
-mikey09120
JThiessen
JThiessen's Avatar
12.29.2008, 03:58 PM
I'd save yourself the headache and get them anodized or better yet - powdercoated. Our local powdercoater will do small parts for about 10 - 20 bucks a part, as long as you are using one of thier standard colors. I even had some done for about 5 bucks a part - he just threw them in with another customers batch - I didnt care that much about the color on those, but you pay for what you want....
If you are trying to clean up a piece that has lots of ridges, for example a heat sink, you will be best off getting it sandblasted. Second would be a chemical prep - but you have to have the right chemicals for that, and it would be expensive to obtain all the right ones. Next would be to go purchase about 10 of those stainless wire wheels for your dremel and go to town on it. Once you are done removing material, put on some rubber gloves and clean it thoroughly with denatured alcohol. Dont get any fingerprints on it....oily residue is very bad.
I'll second the "no clearcoat". Todays paints dont need it.
Getting any paint to resist scratching is quite a challenge. I've tried baking parts after painting, and had maybe a 25% success rate with it. You really need an advanced paint that is mixed specifically for that to make it work.
In the end powdercoating has been the best thing I have used.
I found my powder coater by talking to some local bikers - they all use powdercoating for their custom choppers.
12.31.2008, 02:40 AM
sandblasting won't pit aluminum?
JThiessen
JThiessen's Avatar
12.31.2008, 12:38 PM
No - you use a different media and volume rate depending on the material. Bead blasting is actually more common now than sand blasting.
