01.01.2009, 11:40 PM
Originally Posted by TwzteD View Post
Anybody Know Anything About The Emaxx Tranny Conversion? Is It Good? i think it would be a little bit easier to make a motor mount and maybe run 2 packs on the side of the chassis?. Probably Cheaper.
The old emaxx motor plate will not accept the kb motors due to the different bolt pattern. And the old emaxx tranny is too weak, unless you use the gmaxx single speed conversion, and the revo slipper mod. The new erevo tranny will bolt up to the motor, but after you add it all up it will cost more than the tdr mount. Plus you will have to make a new chassis, or adapter plate to mount the tranny to.
You still have all of the same issues, plus the side battery mounts are not ideal. You want the weight of the batt as far forward as possible.
