ssspconcepts
ssspconcepts's Avatar
01.04.2009, 07:32 PM
I have had good luck with the MIPs...they are are 5.5mm at the shaft and 6mm at the axle (.5mm thicker than most others at the shaft) and probably the strongest available since UE no longer sells CVDs. Just make sure you grind a flat spot on the retaining pin and use plenty of red locktite.
