George16
Supermaxx
George16's Avatar
01.05.2009, 05:52 AM
Welcome to the forum.
What emaxx do you have? I have a gmaxx with a 1515 1Y 2200Kv running on a pair of 3S 5000mah for a total of 6S. The speeds are insane. This is basically my speed truck.
ANy enerland-based lipos such as Neu, Flightpower, Polyquest just to name a few are the best packs out there. Then are are also cheap lipos which are getting good reviews such as Zippy and Rhino.
If you run 2 5S lipos in series, it will become 10S which will smoke your ESC. You want to run it in parallel to increase mah(runtime) while keeping it at 5S. I use a pair of packs to balance the weight on both sides of my truck.
There are different good chargers out there such as Astro, Hyperion. I'm using a Hyperion Duo which charges a pair of batteries at the same time. No, you don't need a discharger.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
e maxx rules
chrismechanic
e maxx rules - 01.05.2009, 09:18 AM
hi george/all...thanks for the reply, i have an original 3906 e max with the pro line wide kit, full mip cvd kit, rear diff lock and ally bulkheads (fastlane i think). in the pipeline is a 40 - 50mm chassis stretch and 13mm offset rims.
love the look of the g maxx chassis but want to retain original ground clearence. also think i will need ally diff casings and maybe ally g/box and steel cogs.
yer parallel 5s, lol dont want no fires.
i trust enerland is a battery company?
ive looked at a hyperion charger on a main hobbies (is that a good place to shop they sent my maximizer rims through fine, good price too) looking at EOS0606i charger will that one be ok?
also was looking at protek lipos. 5s 30c 4500mah the supreme power range will they be ok? these produce 135a is that enough for mmm 2200kv combo?
as for usage it will be bashing more than all out speed.
thanks, chris
