Thanks.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Thanks. - 01.05.2009, 07:06 AM
Thank you Lito. I just sent a PM to Respi, so we will see if I am too late to get in on the order. He stated that he is only going to have enough adapters made to outfit 25 projects (at 5 pieces each order). The 17mm wheels was the only reason I was kind of hesitent about picking up your UE shafts. I plan on only using the Axial beadlocks from now on. Once I have enough wheels setup I will probably sell off all of my CA glued wheel sets. Anyway thanks for the info. We shall see how that goes. Later Man.
Jerry, Menardo (respirology in the UE forum) will be making them. I'm second in line (actually first since he's making them) on the list to get a set. Here's the link.
http://www.unlimitedengineering.com/...=21327&acon=39
Go there and order a set.
