sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
01.07.2009, 11:10 AM
Not true losses increase with square of current W = I * I * R...
Yes, that's correct. Higher voltage will be more efficient.
You can have all the watts, but electric motors also makes power from torque and that's where a lower Kv motor (Brushed or Brushless) will have the advantage.
Torque produced by a BL motor is a function of the can length. Once you saturate the magnetic field, they all make the same torque. So a 7700kv can make the same torque as a 4600kv, provided you can supply enough power to saturate the coil. Once it's saturated, all the power in the world won't change matters. If you want more torque, you need to go to a longer can.
This is further backed up by Castle's site:
A high power capable brushless motor in electrical engineering and physics terms, has unlimited torque. We live in “the real world” so technically for us that’s not totally true, but – a brushed motor has a torque level that due to its design has an upper limit, regardless of how much power is being applied to it. That limit is low enough that you can see it clearly on an average track On the other hand, a high power brushless motor’s limit to torque in an RC vehicle is not within the bounds of the motor itself so much, but rather falls on the ability of the battery to deliver current to it. We generally don’t describe these motors in terms of “one has more torque than the other”, but rather “the 7700Kv motor is faster and draws more current than a 5700Kv motor in the same vehicle”. It draws more current, because it’s making the car go faster and doing more work than the 5700 motor is. As long as the batteries used are very good at supplying current without an excess of voltage depression (low internal resistance is good) both motors will appear to have the same torque, even though one is much faster than the other.
and this:
So think of torque as a function of battery capability only.
So low kv does not equal more torque.
lutach
lutach's Avatar
01.07.2009, 12:40 PM
and this:
Castle Creations (With the Chinese slotless motors) is new to the brushless motor scene compared to Aveox (Neu included since Steve used to work at Aveox), Plettenberg, Lehner, Hacker, Mega and some other companies. Yes the can length has to do with torque mainly because of the length and/or diameter of the magnet. Take a lower turn Kv Nue motor and put it against a higher turn Kv motor and see which one has a higher Kt. I know first hand that my Neu 1515/2Y has more torque than my Neu 1515/1.5Y. I thought the .5 turn difference wasn't going to be noticed, but it is not by much though. Aveox has a nice way of calculating all of this, but I only have PDF files of it. I'll probably take a screen shot and post it here.
sleebus.jones
01.07.2009, 01:03 PM
Cool, I'd like to check that out.
lutach
lutach's Avatar
01.07.2009, 01:17 PM
I have attached the PDF file. The other one I have is bigger then what's allowed by RCM to upload. I can e-mail you the other PDF file and you'll find some interesthing data on page 5.
Please look at the 1406/4Y which has a Kv of 1500 and the 1415/1.5Y which has a Kv of 1568. You can see that the Torque Constant In OZ/AMP of the 1406/4Y is higher then the one from the much longer 1415/1.5Y.
