E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.07.2009, 01:10 PM
Personally I would run 4s with the mmm 2200kv combo. 5s will be a bit on the crazy side! Running 4s will still safely get you into the 40+mph range. Most any battery that can handle 125 amps continuous should be fine. Two 2s backs of at least 5000mah ran in series would prolly be your best bet, IMO.
Hyperion makes a great line of chargers. The 0610 or the duo would be your best bet. The 0606 is only a 50w charger, it will work fine, it will just take longer to charge your batteries.
