01.08.2009, 02:43 AM
Ok, can you disassemble the dst diff for me?
My thought is to look at the part of the diff where the output comes out of. Is it one piece with the spur, or does the spur bolt over it, like a cap? I am guessing that it is made similar to the plastic kyosho spurs. Can you maybe use one of them to get a 10mm output insted of 12mm?
Depending on the diff output size, most are 6mm, you should be able to turn down that area to fit a 10x16 bearing. Then do the same on the cup end and use a rcm kyosho mount and matching front bulkhead.
