01.12.2009, 12:02 PM
I've seen a diff lock mechanism around somewhere that simply replaces the inner spider gears and locks it. IIRC, it was for a savage. Couldn't something similar be machined for the common diffs (Mike?). Using really thick stuff is possible, but is a PITA to clean out if you decide the change it.
maximizer r/c made a few. ofna makes a spool for gtp center diffs, i deduce it would work with any 1/8 scale diff. Mike needs a few more mills and an asian country to keep up with our wants
