Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
dangerwr
01.15.2009, 01:27 AM
I have yet to hear of anyone running a 2-speed brushless on the DM-1. When I was building my Super RS4 (EP) I heard a few people talking about using the 2-speed from the Nitro version. What I gathered was that there was little need since the electric motor has a flat torque curve and would not benefit much from the 2-speed. I do not know personally but will be interesting to hear how yours works out with the 2-speed.
If you have the room I would think a 2-speed on a larger 1/7th scale would be fun. How do these things shift? Do they use some type of centrifugal clutch mechanism that switches out at a certain RPM?
01.15.2009, 01:37 AM
exactly, a centrifugal clutch and a one way bearing. when the second speed hits and overrides the first, the first just spins freely because of the one way
year1camaro
year1camaro's Avatar
01.15.2009, 02:08 AM
The dude who started this post was using a 2 speed, but he din't reply as of yet. One certain benefit would be torque curve, if you could keep it hooked up.
jhautz
jhautz's Avatar
01.15.2009, 03:40 AM
Still running the 2 speed in mine. Works great. RCMonster even makes a 2 speed pinion adapter now so you dont have to make your own like I did back then.
RCmonster Mike built an InfernoGT last fall and used the 2 speed also.
EDIT: In post number 85 in this thread there is a short video of the car running and you can hear it shift. The pitch of the motor and gears changes when it shifts. Its like a little turbo boost kicking in.
to make it...
or break it...
Silent...But Deadly
A couple of photos of the DM-1 Spec conversion . . .
dangerwr
A couple of photos of the DM-1 Spec conversion . . . - 01.15.2009, 11:57 PM
Here we have my latest creation. I am using the solid spool with the center shaft and out drives from the 2-speed. Also, I started with a Novak conversion kit but am abandoning this idea for a RCPD top plate and motor mount with a RC-Monster battery tray.
My current plan is to use a MMM v3 and a Neu 1512 1.5D/F. I think I will gear this 3300Kv motor at 14/51 on 4S to start and see how things go. Hopefully they go fast!
Oh well, it will be several weeks for the RCPD stuff to get here so this will be it for a little while. I might anodize the parts red if I can piggy-back an order from work. Cheers!
01.16.2009, 10:49 AM
Nice start man! Keep the pics coming.
ssspconcepts
ssspconcepts's Avatar
01.18.2009, 04:01 PM
Brushless OFNA DM-1 SPEC: Flightpower 5S 5000mah (25C) Battery, Mamba Monster Speed Controller, Neu/Castle 1515 2200kv motor, 51T Mod1 Spur gear, 25T Mod1 pinion (I know this is too big...but its fast as heck and fun), and Spider Eight 43/13 ring and pinion differentials.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 25
Total Voltage: 18.5
Motor KV: 2200
Tire Diameter (inches): 4.17
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.04 : 1
Total Ratio: 6.74769 : 1
Tire Circumference (inches): 13.1 inches (332.75 mm)
Total Motor Speed: 40700 RPM
Vehicle Speed: 74.83 mph (120.2 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
As promised here is my amature video...
ssspconcepts
01.18.2009, 06:48 PM
Here are the latest pics with the one speed direct drive installed.
From DM-1 Spec
From DM-1 Spec
year1camaro
01.18.2009, 10:50 PM
[QUOTE=ssspconcepts;253388]Brushless OFNA DM-1 SPEC: Flightpower 5S 5000mah (25C) Battery, Mamba Monster Speed Controller, Neu/Castle 1515 2200kv motor, 51T Mod1 Spur gear, 25T Mod1 pinion (I know this is too big...but its fast as heck and fun), and Spider Eight 43/13 ring and pinion differentials.
Other Ratio: 1
Total Voltage: 18.5
Motor KV: 2200
Motor coil Ω: 0.006
What tires did you use for this run? Car looks fast fast fast!!! nice...Now to get it to stick to the road might be a challenge with all that power.
year1camaro
01.16.2009, 01:11 AM
I made my pinion adapter also. I probably would not have bought it even if I knew about it.....I'm into the fabrication end of this hobby. I also made the top plate and motor mount. It's cool to hear your not having problems with the 2 speed,,, that was a concern when I started this project. I watched your video, very nice...looks like it works great!
dangerwr
01.18.2009, 06:58 PM
Man that thing is fast--looks very powerful on the 5S. Do you think it is capable of going 70mph with your current setup? I can not wait to finish mine up!
ssspconcepts
01.18.2009, 07:05 PM
The calculations say it is possible to go 70+mph...but I never could get it up to full throttle because the tires constantly break loose. Towards the end of the video there were a couple of passes where I was close to full throttle but not quite. I absolutely have to get a radar gun. I keep talking about it but I keep spending my $$$ on car parts!
By the way...I see some other folks on here are installing one-speed centers. This was a PITA to keep the DM-1 center shaft from sliding back and forth because there aren't any bearing stops milled into the shaft. Brian helped me come up with the idea to make a shim using 8.1mm inner diameter stainless steel tubing and a couple of 8.1mm innerdiameter washers. It worked like a charm. I still have some of that tubing if anybody needs it. If you order it from onlinemetals.com they charge an arm and a leg for shipping.
dangerwr
01.18.2009, 07:26 PM
I bought one of those Hotwheels radar guns off eBay for $20 and works pretty good! I am going to gear mine around 60mph at first and see where the temps are with my driving style.
Now, on the solid center spool I wound up using the center shaft and outdrives from the 2-speed that came with the car and not the little kit. Did you do the same or did you do something different?
ssspconcepts
01.18.2009, 07:33 PM
Yep...had to use the 8mm DM-1 Spec center shaft...that's why you will need the 8.1mm inner diameter steel tubing.
SpeedAssault
SpeedAssault's Avatar
05.27.2009, 10:40 PM
Hey That is a beautiful car Great pics, enjoyed reading
I am blown away that with a ratio of 6.7, a 51spur and 25 pinion that you still have a hard time doing full throttle.!and end up torque fliping
maybe you could move the motor forward ...
whats the weight?
The video was cool,looks like you need a circle track. definitely shows the power and speed, amazed to see it flip
Looks like I'm going to mount my motor in front
Thank you for posting video , I was going to run a 10:1 ratio but going to change to 5 or 6:1. although it's 9lbs and 21" wheels base X 15" wide so there shouldnt be any torque flippin
wish you were closer so we could race, when mine gets done that is
still working on it, needs a motor mount and tire adapters for the 1/5 but also make it easy to put on 3.2 wheels for the offroad stuff
again great build thread
Sweet ride, cant wait to see a new body on it, keep it coming
