George16
Supermaxx
George16's Avatar
01.15.2009, 03:56 AM
Well, my buds run 55t motors on 3s lipo, and with 2.2 tires and axial trannys geared 14/87 they get about 5mph out of them. I prefer a bit of wheel speed as I think it can be an asset when crawling. A 55t motor has a kv of about 1100, so the speed calc may be useful. On 2s figure 3.5mph with stock gearing on an ax10.
If that's the case, I'll just run it on 3S. I have a couple of Neuenergy 5000mah 3S batteries for the truck. Thanks.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
01.15.2009, 11:38 AM
The 55t motors definately perform well on 3s. With a 5000 pack you will get about 1.5 hrs of runtime, possibly more!
I use 2100mah lipos in my 2.2 comp rig and it does at least 35-45mins. And that is with a big outrunner. With the low gearing and speeds crawlers are setup for they barely draw anything.
