bensf
01.16.2009, 10:51 PM
With the same battery and driving style- in principle, you will get a longer run time. Higher motor speed with lower gearing will reduce current draw and therefore give longer runtime, but there are an awful lot of variables and 'what ifs?' to think about:
Lower kv motor & higher voltage with the same gearing would be best and certain to give better runtime- you didnt mention your voltage....
No change in voltage, just kv and gearing. It really depends on what motor it is and where the most efficient RPM range is.
01.16.2009, 10:53 PM
Anyone know what it is?
