01.16.2009, 10:54 PM
"Awful lot of variables and what-ifs?"
Higher kv and lower gearing is what the original question was, and yeah, that would yield better runtimes (not massively though I expect).
Going with lower kv and higher voltage would yiled the best results- the whole 4s & 2000kv vs 6s & 1600kv thing.
Jason
01.16.2009, 11:13 PM
ok .. so a 3500kv motor on 3s 11.1v give more runtime then a 3500kv on 2s 7.4v geared for the same speed ?
Mozzy
Mozzy's Avatar
01.17.2009, 12:42 AM
You're also forgetting one important factor in this equation, the battery capacity.
We all know 2 & 3s is 7.4 & 11.1v respectively, but, are you just changing kv & gearing to keep at your 40mph to determine if your runtime will remain the same?
As Neil said, get a stop watch. Don't take anyone's word for it as we all use different packs, motors & gearing & they all perform differently.
Do the testing yourself & then you will know.
I've done my testing to get my cars to where they are. Yeah, it may have cost me money to buy the motors, but, I just sold what I didn't want & got a decent price for them.
I learnt a lot doing it too.
Good luck what ever path you choose.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
Jason
07.02.2009, 06:28 PM
whats give me more runtime in :
lower tooth spur gear and lower pinion
or
higher tooth spur gear and higher pinion
geared for the same speed ..
