bensf
01.18.2009, 12:42 AM
Is the trans the smae as the emaxx one? If it is that gearing seems a little high. Put it into BrianG's spped calc and gear for 40.
sikeston34m
sikeston34m's Avatar
01.18.2009, 01:04 AM
You're probably walking the line as far as ESC temps go, but if you look back through some of the threads under Castle Creations, you will find more information about the ESC temps and operation of the cooling fan.
The fan comes on at 140 degrees, and doesn't shut off until it gets below 140 degrees.
This is well within the safe operating limits of the ESC.
If you want it to run cooler or want more runtime, then gear it down some.
My 2 cents.
