drkros3
01.18.2009, 08:49 PM
the 6s battery have a 25c discharge rate so it should be enough.
if i ran a 13/44 do u think i well have over heating issues?
SeanZ0r
01.19.2009, 05:19 AM
Sounds like a cool setup, But Id rather get a 4s setup with 6000mah capacity, and you should have killer run time and keep the MMM combo happy with lower temperatures.
AE Factory Team TC4 4c2p 6000 & MM 5700
Brushless Traxxas Jato MM 5700
SH Z-Car MMM2200/5s4000mah Turnigy Packs
nik77356
01.21.2009, 05:19 PM
On 4s the system would run hotter and have less runtime.
What brand of batteries do you pla on getting?
bensf
01.21.2009, 05:26 PM
Why with more voltage and fewer amps systems usually run cooler. It will spin the motor at 48k rpm, but I wouldn't say that it is too high.
SeanZ0r
01.21.2009, 05:29 PM
ohh yeah thats true, there will be less amps provided so it would be running cooler. MY BAD
