Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
BlackedOutREVO
01.19.2009, 02:46 AM
What/who makes that spool?
And any tips on building this puppy up? My buddy is building one currently, and wants a speed machine, CC combo, 220 KV, 5s, and a zippy 4000 mah batt
dangerwr
01.19.2009, 10:01 PM
Ofna makes the center spool. There is a picture and part# back around page 8 or 9. Let me know if you can not find it and I will look it up . . .
ssspconcepts
ssspconcepts's Avatar
01.19.2009, 10:15 PM
If you want a single speed center, then you will need these parts. You can either buy them separately or use parts from the stock 2-speed to build the center:
http://www.nitrohouse.com/catalog/pr...ducts_id=12086
http://www.nitrohouse.com/catalog/pr...ducts_id=11306
http://www.nitrohouse.com/catalog/pr...ducts_id=11016 (you can ditch the shaft that comes with the silver aluminum spur mount)
http://www.nitrohouse.com/catalog/pr...ducts_id=10760
http://www.nitrohouse.com/catalog/pr...ducts_id=12091
You will also need a 13mm long piece of 8.1mm inner diameter steel tubing and a couple of 8mm steel washers because the 8mm center drive shaft does not have bearing stops milled on it to prevent the shaft from sliding back and forth.
BTW...this thing is nuts on 5S. I had a hard time keeping the tires from spinning with my 5S/2200kv. I couldn't imagine 6S.
