Go Back   RC-Monster Forums > Support Forums > Novak
Charlie
01.19.2009, 04:05 PM
Howdy,
The HV Pro ESC has a circuit inside that protects the ESC from "Servo Voltage". This circuit needs to be turned on then off.
So when you turn on your RX battery pack/UBEC, the ESC will not run the motor, but the servos will work. At that point, turn the ESC on, then back off again. When you run the car, always have the ESC off.
Older HV ESC's do not have this protection, so this extra step of switch flipping is not needed.
The ESC will not work correctly if you remove the red wire from the input harness.
starscream
RC-Monster TQ
starscream's Avatar
01.19.2009, 07:02 PM
I actually like the way the Novak HV Pro performs better than my MMM. The Novak is more drivable/raceable for me. The throttle response and power band of the Novak fits my racing style much better. I am still using the MMM in my truggy so I am continueing to investigate throttle curves etc to make the MMM more raceable for me.
You should be able to use a simple series adapter between your esc power inputs to accomplish this. Charlie is right on with his post.
The HV Pro can handle 5S Lipo but from what I've heard the esc heats up just as much as it does on 4S. I haven't tried 5S as I am having very good performance with 4S.
Ha Ha
JThiessen
JThiessen's Avatar
07.19.2009, 06:50 PM
Originally Posted by Charlie View Post
Howdy,
Why is this information not included in the "Using a Reciever Battery Pack" section of the instructions....?
Just spent a good 2 or 3 hours trying to figure out why the ESC wouldnt come on after following the directions in the manual.
Bad Novak, Bad Novak!
