I'll check
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
I'll check - 01.20.2009, 08:04 AM
Dagger, so far, I haven't had any problems with the grade 14.9 screws. Never strip or break any of them. I used them on my pinions and hinge pins. Bolt depot is cheap too.
Jerry, ask your contacts in Korea where to buy those enerland lipo cells. You might be able to buy them cheap wince the won is very weak against the dollar.
Thanks Lito I will have to check that out once I get out in the local community. I would not mind building my own packs if I could get the cells cheap enough. I also really like the armour plated "HexHead Screws". The stainless screws suck, and the black oxide don't seem to hold up to the torque of tightening things up. Those hexheads are pretty good screws for the money. I will try out the 14.9 screws just to see how they compare.
