Ryu James
Ryu James's Avatar
01.20.2009, 08:39 AM
yeah, that sucks bro. frustrating huh. you can cut into the endbell but i wouldnt. i did this and once you start it never stops and your motor looks like crap. plus you usually have to cut away way more than you had anticipated. i would get a another piece of 3mm alum or carbon and make the spacer thicker......or buy a tekno conversion kit.....at least that is what i would do next time if you plan to run mechanical brakes. Mike sells the kits on his site or you can get them from impaktrc.com. good luck.
Jammin SCRT10 Neu 1512 1y
starscream
RC-Monster TQ
starscream's Avatar
01.20.2009, 08:58 AM
3mm isn't much
An easy solution to this is to run slightly bigger gears.
What vehicle are you using. What is the current pinion spur? 46/15?
it sounds like 48/16 would fix you up.
You can always run your 17T pinion and set your throttle end point down to 85 or 90% until you get new gears or make a small spacer.
Ha Ha
Ryu James
Ryu James's Avatar
01.20.2009, 09:13 AM
cdis,
i was going to suggest that you get a larger spur instead of just trying to make it work with a larger pinion. just take what your ideal gearing is and divide the 2 numbers to get the gear ratio. for example 15/48 is ratio of 3.2 so if you need to go to 50t spur then figure what pinion will get you close to the same ratio and your setup will be very close to what you wanted in the first place. eg. a 16/50 ratio is 3.12. just go up in spur size and this will require a larger pinion also and the result will be a mesh that works with your current spacer. if you already have a 54t spur on then i dont know what to tell you. i havent seen mod1 gears much larger than that.....although i am sure you could find one somewhere.
cdis
01.20.2009, 09:25 AM
Yea it is a bit frustrating.
I agree starscreem, 3mm isn't much, but it should be just enough to allow the brake pads to clear the front of the motor. 3mm Alu is just what I have on hand. The problem would be to make up something as accurately as Mike has done for the brake spacer.
The car is a Kyosho ST-RR. It's running the stock 50T spur gear at the moment. I was thinking about getting a bigger spur gear, but no one in Australia carries parts for the ST-RR yet... Should a got an RC8T lol.
Anyway, yea, if I could, I would run a bigger pinion and maybe the 16 or 17t pinion, whichever one fits best.
This is only an issue until the Medusa arrives. I've ordered the 1600kv motor, so I'm hoping that I'll be able to use the 17T pinion with 7s1p A123 and get some decent amp draw and run times.
Thanks Ryu, I didn't know that formula for working out the gear ratio :D
starscream
RC-Monster TQ
starscream's Avatar
01.20.2009, 09:38 AM
From your picture, it looks like you could go with a smaller brake disc. The smallest disc I know if is the Losi 8ight rear brake disc. A smaller diameter disc my give you the extra 3mm you need.
Ha Ha
cdis
01.20.2009, 09:43 AM
A smaller diameter brake disk wouldn't help would it? What would be more helpful would be either thinner brake pads? Then the motor would fit "over" the top of the end of the screw that holds the brake pads together, which you can see is touching the front of the motor, and hindering it from moving any further toward the spur.
