Twin motor setup.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Twin motor setup. - 01.20.2009, 11:07 AM
A lot of guys just do not like or recommend V-twin setups due to the added weight issues. The arguement is why put two motors on when you can purchase one motor that will give you the same or more power than a v-twin system. You can use the Novak Super Duty XR ESC to run two motors. There are a few other ESC's that will work, and I am sure that you will soon get a ton of responses for this both good and bad points. Good luck with that RIver. You may have read some of my responses as I am building a SuperMaxx right now with Twin Dewatl 18v 970 motors. It has been done before, but I wanted the experience with that setup anyway. I am using the super duty myself.
