Work or not??
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Work or not?? - 01.23.2009, 08:10 PM
That servo saver will work ok, but not as good as the gen IV UE servo saver. You have to work within your means $$$ and that is that. So if that is what you can afford, then that is what you have to work with. Any other option is only going to work so much. If you want perfection, then save your moeny and get the UE gen IV. With any luck UE might get back to making them again this year. Good luck with your endevour.
