mohanjude
Need for speed
mohanjude's Avatar
01.25.2009, 10:45 AM
I think the Losi Brushless conversion is value for money at $79.
However the motor mount is a bit of a pain as it is too thick. Unless you have a long shaft this could be a problem. The 2 holes to mount the motor are also to large and you do need drop a small copper tube to manage with the usual 3mm screws. However once you find the right motor and pinion ( I used a Neu 1515 2200KV on 6S with a 18 tooth pinion on my Losi Truggy & 4s 2700KV with 16 tooth Pinion on the 8ight Buggy) you will have no further issues. The battery tray will accept very large Lipo packs. The whole installation looks neat and factory assembled. I also tried Mikes Motor mount which is very good if you dont want the issues with the Losi Motor mount.
Tobbe
01.25.2009, 03:17 PM
Oh I see. That's a shame about the motor mount. I think I'll go for the RCM mount then. I'm planning on using a Neu or a CC Monster combo and I don't want to realize that the shaft is too short for the motor mount
FG101C
01.25.2009, 08:29 PM
A freind is using the Castle motor, shaft is long enough. If your real good you could pull the front face plate off and retap the holes to 4mm, then it would be ok. Then just to find the right gearing since your a little bit limited on the spur size.
ReV:-O
RC-Monster Carbon Fibre
11.12.2009, 05:56 PM
Do you know the battery box dimensions?
