01.26.2009, 09:08 AM
Disagree - The 2650 is close to a 1512 and is suitable; for a buggy for a truggy / MT get the 2200 - I've been running both of these motors since september...
You will notice the difference.
Originally Posted by SpEEdyBL View Post
Put it this way. If you gear the 2200 with a 26 tooth and you gear the 2650 with a 22 tooth you will practically get the same results. Not that you would ever gear that high for either motor, but you get the idea. I have a 2650 kv combo on the way that i will be running on up to 5s. It's the same rpm as the 2200 on 6s so I should be fine for my intended use...
...of showing off in the parking lot for 20 minutes straight that is. lol.
