George16
Supermaxx
George16's Avatar
01.30.2009, 07:30 PM
How is the ESC on/off switch attached to the ESC?
Nice truck!!!
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Electric Eel
01.30.2009, 07:51 PM
The diffs are already shimmed out of the box. Each side has 2 0.2mm shims. The pinion has 1 0.2mm shim. Very little play.
Nope, no grease in the tranny.
The switch is mounted to the ESC plate. It is completely sealed with a flexible hood. It's the white square in the last picture behind the three motor leads.
Weight is 11 pounds 6 ounces. I already bought an extra bulkhead and R&P set just in case. The HPI website has them in stock.
JThiessen
JThiessen's Avatar
01.30.2009, 09:46 PM
What are you running it on - 6S? I'd like to know how this thing runs on 4S - seems heavy for 4S with a 2200KV motor.
