azjc
01.31.2009, 07:52 PM
I eat as much as I can whenever I can. I am pushin 130 at the moment. I just don't like being so small. I should probably mention I lift weights 3 times a week so I'm not just getting fat.
It's gunna suck when I get to about 30 and I can't eat as much as I want....
ML
if weight gain is what you want, take in as much protien as you can and the 3 main exercises you want is Bench Press, Squats , and Dead lift you do all these things you WILL gain weight, also don't over workout or you will get weaker/smaller...this happened to me before. I was working out 6 days a week
Metallover
RC-Monster Spudgunner
Metallover's Avatar
02.01.2009, 12:35 AM
Originally Posted by azjc View Post
ML
Well first off, I am not allowed to do bench presses because my baseball coach says it messes up your shoulders.
With working out too much, I don't see that. I have a friend named Leland. He lifts 6 days a week... for 4 hours. He is huge. he's been lifting for 6 months and gained like 20 pounds. I don't think it's healty though...
If anyone cares, he's 15, around 180 and he hang-cleaned 4 reps at 215.
azjc
02.01.2009, 10:53 AM
the one exercise my high school baseball coach stressed was dips, this also helps with increasing your benchpress strength, and if your friend wouldnt workout as much he would be bigger.
building muscle needs 3 equal things to be done and one of them is not more important than the other
1. Working out ( lower reps, heavier wieght builds more strength/muscle size, 6-10 reps per set)
2. get plenty of rest
3.quality diet
the science behind building muscle is when you lift wieghts you break down (rip) the muscle fibers and your body will repair those fibers plus a little more and this is what makes your muscles bigger, if you workout too much you never allow the fibers to rebuild. I dont know the amount of time your friend gained these 20 lbs. Expect to gain 10 lbs of lean muscle a yr doing it the right way ( no steroids)
