Help with build a strong diff ! What to use?
emaxxter
Help with build a strong diff ! What to use? - 02.03.2009, 12:52 AM
I blew out my stock 3905 diffs with the MMM brushless combo. What can I buy to make these these stronger? It seems to be that really big gear that is stripping out... Any advice?
George16
Supermaxx
George16's Avatar
02.03.2009, 01:57 AM
Buggy/truggy diffs are good alternatives. Ofna, Hot Bodies etc. However, none of these will last if not properly shimmed.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
jayjay283
jayjay283's Avatar
02.03.2009, 03:19 AM
FLM hybrid http://www.rc-monster.com/proddetail...LM18700&cat=31
with hotbodies diffs http://www.rc-monster.com/proddetail.php?
8 spyders http://www.unlimitedengineering.com/...re/13540B.html
6 spyders http://www.unlimitedengineering.com/...ore/13540.html
Duster_360
02.03.2009, 08:01 AM
The 16.8v diffs from the 3906 are stronger than what you just destroyed. I'm running a set unshimmed in my 3905 and they are better tha the stock diffs. They are an intermediate strength solution to this problem. The FLM hybrids are prob the best all around solution, but are pricey and need to be shimmed as pointed out. Go to Ebay and find the diffs for use in them, you can get them for about 1/2 as much than elsewhere.
Using buggy diffs will re-gear your EMaxx so be prepared to make a spur/pinion gear change to compensate.
George16
Supermaxx
George16's Avatar
02.03.2009, 08:16 AM
You're not making sense at all. Are you saying that the 16.8V diffs from a 3906 are stronger? The 3906 uses the weak 2-screw diffs while the 16.8V(3905 emaxx) uses the stronger diffs.
He said he already destroyed his 3905 diffs.
Revo with OS .18TZ
emaxxter
02.03.2009, 11:16 PM
So if I buy the hybrid bulks and the truggy diff:
http://www.rc-monster.com/proddetail...GY_DIFF&cat=17
and
What do I need to connect it to my center driveline and driveshafts. I use these CVD's for center and drive:
http://www3.towerhobbies.com/cgi-bin...151r&search=Go
and
http://www3.towerhobbies.com/cgi-bin...?&I=LXPNJ8&P=M
Duster_360
02.05.2009, 10:30 PM
[QUOTE=George16;258238]You're not making sense at all. Are you saying that the 16.8V diffs from a 3906 are stronger? The 3906 uses the weak 2-screw diffs while the 16.8V(3905 emaxx) uses the stronger diffs. [QUOTE=George16]
My bad, I read that as the older 3906 diffs he had destroyed. I know all that stuff, I just read it wrong.
George16
Supermaxx
George16's Avatar
02.03.2009, 11:49 PM
The hot bodies pinion shaft is 8mm. You need to buy Mike's adapter in order to use the traxxas centers.
Revo with OS .18TZ
emaxxter
02.04.2009, 12:04 AM
do you by chance have links to the adapter or can tell me where to get it? is the adapter for the pinion or the output shaft to the wheels?
Unsullied_Spy
Unsullied_Spy's Avatar
02.05.2009, 11:33 PM
http://www.rc-monster.com/proddetail...mrevov2coupler
That's the part you'll need to connect the diffs to the center shafts. The hybrid diff should fit just fine. I wouldn't bother with the UE diffs, AFAIK they're Ofna diffs which can be bought much cheaper.
emaxxter
02.04.2009, 12:40 AM
Anybody?
emaxxter
02.04.2009, 12:44 AM
Here is a pic!
and
emaxxter
Does anyone know if the Hybrid bulks with fit okay with the GMaxx G4?
mkrusedc
NeuMaxx
mkrusedc's Avatar
02.04.2009, 01:34 AM
Don't use the truggy gears use the buggy gears. These:
http://www.rc-monster.com/proddetail...GY_DIFF&cat=40
They will be closer to the original ratio than the truggy gears and you will not have to compensate as much. My hybrid bulks and HPI buggy gears are holding up fine to a 5s/2200kv set up.
emaxxter
02.04.2009, 01:10 PM
george16.. can yo comment on my last question?
