JThiessen
JThiessen's Avatar
02.03.2009, 10:48 PM
Couple comparison shots with my 3.3 Revo conversion
[IMG][/IMG]
hmmm - Flux is supposedly 1/8th scale, Revo 1/10th....doesnt look any different to me...who's right?
A few misc pics:
[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
Manual is nice - much better parts list and diagrams than I've seen from Traxxas. Down side is the multilingual crap. No offense meant to those who need it!
Good lot of some spare parts included.
Included tools are on the cheap side, and not all tools required for assembly/dissassembly are included (which I beleive Traxxas does provide).
After scrounging for some AA's that actually worked, I proceeded to try to program the ESC - didn't go nearly as smooth as my MMM. Not sure if that's due to the difference in 75Mhz vs my 2.4. Anyway, it took about 5 tries before I was happy with it.
Another note - these battery trays could really use some help. First, what's up with those rubber caps for the latch's? They dont fit under the tab very well, and come off too easy when you forget that they dont open the case.
Second, the doors dont open far enough - the latch's hit either the ESC, or the radio case, preventing them from opening far enough to easily put a battery it. Next, I was using a pair of 3S Zippy K's (4300). Very, Very, very tight fit. Even the wires going through the wire opening were tighter than I liked. Part of that is due to the nice braided wrap I have on them, but I'm also glad it was there due to the tightness.
Wheel nuts are extremely tight from the factory - I was going to swap off the rims/tires right off, but after rounding off the first nut, I decided I wanted to RUN the damn thing first!!! I'll tackle those rims next time.
JThiessen
JThiessen's Avatar
02.03.2009, 11:00 PM
Now for the Run:
Very little if any glitching at low throttle - I expected some with the 75mhz.
Wheelies, wheelies, wheelies....much more than I have experienced with my Revo (MMM/1515 2.5D). Just guestimating - at about 45, give it a blip of throttle, and its on its lid...guess I should have put the included wheelie bar on, huh?!?!
I ran it for about 10-15 minutes up and down the street. Probably achieved 100 yards or more on its lid. And it now has the road rash hole to prove it.
The slipper seemed to loosen, and it was getting dark so I pulled it into the garage, spent about 7 minutes finding my needel nose (to remove those damn clips!), and took a couple pictures, and then remembered to take temps. The motor and batteries were 70 deg F, the esc 110 deg F. Ambient temp was around 45 at the time. So I think the ESC may run a little warm with the setup I was running - but I'll have to run it a little more to really know. I did not hear the fan come on at all while running it.
BTW - thank God for Spektrum, as my antenna is already shot from skidding down the asphalt on its lid!
My opinion right now is that its a decent truck, REALLY needs more length and width. It is far too fast for its handling capabilities (on 6S). I do think this will run good on 4S, so I'm in the market for a pair.
Battery trays need some serious improvement/expansion.
