hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
02.06.2009, 03:23 PM
Originally Posted by blueb8llz View Post
still no wheelies. i thought for sure once i put them smaller tires back on, it would wheelie. are you sure theres no slipper for the rc18mt?
actually, the 1/10 on road tires were the most likely to pull wheelies. They gave the truck a higher COG.
If you describe the foamies as "drifter" style tires, then I have to assume its the surface you are running on that is causing the slip and ruining all of your wheelie fun.
The only other thing I can think of would be that the diff balls are shot and the gear in the diff is spinning out....but that would really take more torque then I think that little truck has.
As for the battery, listen to link. He knows better than I. I dont think a higher C rating will make a difference. I really think the slip you feel is the tires losing grip on the surface you are on. ....could be wrong, but that makes the most sense to me. I had that little thing doing wheelies on command.
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
