himalaya
himalaya's Avatar
02.12.2009, 01:39 AM
Nice conversion, pretty similar thoughts to mine, laying down both betteries as low as possible.
I am running 15/48 gears under 6S 25C 5.2Ah LiPo for the winter, motor temperature is well controlled around 40~50C. when summer comes I think I may have to gear down to 12/49.
....What a Blue Sky....
Steeni
02.12.2009, 03:29 PM
Hmm....seems you're running an even higher gear ratio then me...with 6s!
What motor do you use in that setup, All I can see it's no Castle/Neu and it seems smaller then mine?
And yes, I did try and keep the weight center as low as possible while keeping the best left/right weight ratio possible.
