bdebde
That's All Folks!
bdebde's Avatar
02.14.2009, 06:53 PM
What ESC are you trying to get to? I believe the MM will not work in vista.
02.14.2009, 10:33 PM
I finally got v 3.05 to stay in the computer and work! Now, when I download the new v 3.12 and try to link w/the esc it says invalid controller. At least I can adjust the esc.
I am trying to link to the mm esc. I had v 3.05 working before, but, when I went to upgrade, that is when the trouble started
JThiessen
JThiessen's Avatar
02.15.2009, 01:11 PM
Might have helped if you had posted this in the correct forum - they probably don't monitor this one.
Can you adjust the controllers manually instead?
halfcab
halfcab's Avatar
02.15.2009, 04:20 PM
you need to re install as the administrator right click the install and install as admin, I was having the same problem when trying to check settings on my monster maxx, major pita, melted the plugs off of my batteries because the esc was set to brushed mode and I could not check it
mmm v1/cc bec
neu 1515 1y f
ofna hyper7
several crawlers scalers and comp rigs
cc 4600 mm sys in a slash and a stock slash
soon to be reserected gorilla maxx v2
02.15.2009, 04:43 PM
I tried that 4 times, w/no luck! That what's was so frustrating to me. I have upgraded to the newer versions 2 other times via Castle's site w/no probs.
For now, I can at least change settings on the esc.
halfcab
halfcab's Avatar
02.15.2009, 06:23 PM
vista sucks ass
mmm v1/cc bec
neu 1515 1y f
ofna hyper7
02.15.2009, 08:36 PM
vista sucks ass
At times it sure does...at other times it is pretty good
