02.15.2009, 10:26 PM
I like the idea of some used/surplus parts... I will have to look into finding some used motors, and possibly controllers. Wonder if the forklift parts would work? I am guessing that they run on lower voltage that I plan to use.
sikeston34m
sikeston34m's Avatar
02.15.2009, 11:01 PM
What voltage do you plan to use?
I think I have a couple of 350 amp brushed controllers that are 24 volt.
They are made by Curtis Instruments. If you're interested, I can get you the model number and the spec sheet.
02.15.2009, 11:12 PM
Definately... I wonder what they can handle?
sikeston34m
02.15.2009, 11:19 PM
I'll pm you tomorrow with the specs. I have to go to the shop and get the model number.
I do remember looking up features about them. Curtis makes a good line of controllers. IIRC, most of their models can be controlled with rotary or linear pots, or even pwm (such as a servo tester does or a receiver for that matter).
The sky is the limit. It all depends on how much money you wanna throw at it.
Here's their website:
http://www.curtisinstruments.com/
lutach
lutach's Avatar
02.15.2009, 11:29 PM
You have my e-mail, let me know what you're looking for and I'll try to help you the most I can.
02.16.2009, 12:04 AM
Definately! I just signed onto DIY electric forum. I now have alot of reading to do, kinda like when I got into bl r/c.
In the 6 months before I signed on this forum i read the entire thing, from the beginning. That was a job, and I still did not really understand till I had some experience.
02.15.2009, 11:30 PM
Thanks James. I am all about doing this on the cheap... I can be quite inventive if necessary. I am wondering if I can run 2 motors together to double up on the power? I was planning to run 12 12v batteries in series for 144v... But I could do a 2p setup with half the voltage... Depends what is cheaper. I am sure the hv setup is better, especially considering the controller options.
Erevocanuck
02.16.2009, 12:01 AM
you might find this interesting
White zombie electric car
Youtube video of white zombie
sikeston34m
02.16.2009, 07:39 PM
Hey Linc,
Ok, I have some updated information on the controllers I mentioned.
They are Curtis 24 - 36 volt brushed controllers and they are 350amp versions.
Both are Model 1187. Each one should be good for 12,600 watts of power.
02.16.2009, 08:21 PM
Thanks Sike. I will have to look up them and see if they will work...
