Steve182
Steve182's Avatar
02.16.2009, 12:36 PM
Sounds like I'll do the 5s. Thanks for all of your help lincpimp, I appreciate it.
Just checked the Hobby City site and both the 25 and 30c packs are out of stock... crap.
| Hyper 8 Pro- MMM, Castle 2200kv / Zippy 4s 5000mah
| Jammin CRT- MMM, Feigao 10XL, 5s Zippy 5000mah
| Savage Flux- Castle 2200kv Combo, 6s Zippy 4000mah
  Send a message via AIM to Steve182
02.16.2009, 05:14 PM
Yeah, I am in the same boat with the 6s 30c packs... I may just backorder one, but I am not sure yet.
No prob with the help, that is all I am here for... and a little comic relief.
Steve182
Steve182's Avatar
02.16.2009, 11:10 PM
Originally Posted by Cartwheels View Post
Buy a few of those Kyosho spurs, they will break on you sooner or later. You'll get good at tearing down your truck to replace the spurs. I like the hardened steel option much more combinened with the hot bodies lsp diff and pinions. The Hot Bodies parts are nice. I really like the spiral cut gears. If you have the money this is the way!
Thanks cartwheels. Once my money situation becomes a little better, I might go that route, but for now I think Im gonna end up using stock gearing.
Any idea how long it takes for them to come in? Im not too familiar with Hobby City or their Lipos.
vbxt
02.26.2009, 03:47 PM
Hey,
Just to chime in about my X1 CRT build. I am running the MMM 2200kv combo, stock 62t spur with a 14t pinion, and 4S 5000 mah Zippy Flightmax 25c batteries. I ran this combo at the track last Saturday for hours without a problem.
The Zippy's seem to perform very well in my limited testing. I didn't bother to take any temps because everything felt to be under 100 degress to my touch.
I have also tried a 13t pinion, but I had problems with the mesh. It would clack as it was braking. It seems that pinions with higher tooth counts mesh better. I would really like to try a 16 tooth pinion with this combo. I've found that with higher tooth counts I tend to get better acceleration because the torque does not hit the wheels so hard causing spin (thus less acceleration).
I will say that if unlimited traction were available, lower gearing would produce faster acceleration, but in the real world where I can spin my tires at will even on pavement, higher gearing gives me better acceleration.
...(On Hobby City order time: I live on the east coast, and with EMS shipping I have seen order take anywhere from 3-5 days on average)
Any ep diff between x1 CRT vs x2 CRT?
superek4
superek4's Avatar
Any ep diff between x1 CRT vs x2 CRT? - 03.14.2009, 05:45 AM
Hi, I m currently racing with my x1 CRT. was thinking to change to x2 CRT. I m using Rc monster's motor mount n servo tray. izzit worth d change n can I still use d same conversion kit?? I m using big bore shocks btw.pls advise thx
