Semi Pro
Semi Pro's Avatar
02.16.2009, 11:35 PM
Originally Posted by hootie7159 View Post
+++1 on the front end slop...i never could get it entirely out....my sc8 and rc8t have zero slop...
where and when does this wobble happen, my 8ight that i just built seems to be really tight
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
02.17.2009, 01:13 AM
run it for awhile.
you'll see what we mean.
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
JeffEmbracedDC
JeffEmbracedDC's Avatar
02.17.2009, 12:04 PM
Originally Posted by hoovhartid View Post
run it for awhile.
Bigtime!
I've been running my original 8ight for about a year and the front end slop is ridiculous. Luckily it's fairly easy to minimize slop. You can shim the hubs and arms with there http://www.amainhobbies.com/product_...oducts_id/2787 and it works well. There's still the issue of the crappily designed steel-on-steel steering rack that develops slop almost immediately. I suggest either getting a king headz steering rack which has brass bushings http://www.amainhobbies.com/product_...ducts_id/27104 or make your own with bearings.
Oddly though - I'm having a strangely large amount of slop in my front wheel bearings as well as the steering rack bearings which cause a good amount of the slop. I'm going to put in new bearings and see if it helps much. I replace them pretty often but I'm not sure if I have for a little while...
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
js058515
Thank You Brushless Gods!
js058515's Avatar
02.17.2009, 09:21 PM
Originally Posted by JeffEmbracedDC View Post
Bigtime!
Thanks for the links to the stuff that has help you reduce the slop. I keep hearing about it and realize that I have a quite a bit on my 8T and 8B.
Semi Pro
Semi Pro's Avatar
02.18.2009, 12:23 AM
Bigtime!
thats good to know
